Offline Maps doesn't update
2543
05-22-2024 08:50 AM
LineChampagne
We are experiencing a problem with the update of Offline Maps in ArcGIS Field Maps. I am wondering if someone else has encountered a similar behavior.
We have put in place a process that allow us to update Feature Service Views using a script that redirect the source of the View from one Feature Service to an updated Feature Service. The services are hosted in AGOL. This redirection allows us to update the View with no down time. Using this method, the replicas created for Offline Maps are preserved and the synchronization doesn’t fail.
The problem we are experiencing is when we try to update the Offline Maps in Field Maps, the updated data doesn’t show up. We are updating the Offline Map area with Field Maps Designer with no error.
If the edits are done directly in the Web Maps on the other hand, the changes show up in Field Maps.
Anybody would know what could cause this behavior?
Line Champagne
Hydro-Quebec, Canada
RhettZufelt
MVP Notable Contributor
Did you just update the offline areas in FM Designer, or did you re-create them?
See here for similar, though not sure you update method is schema change or not.
R_
LineChampagne
We are updating. The schema didn't change.
RhettZufelt
Did you try the re-create option?
R_
LineChampagne
I believe if we re-create, the Field users will have to download the Offline Map again. If they have added/edited items that are not synchronized we will loose those.
RhettZufelt
I don't currently have a test dataset that I can change the schema of but tested this with edits in Field Maps app.
If I re-create the offline area (that was previously downloaded to iOS device), then on the iOS device, I choose sync, it will sync the local edits back to the HFS, then re-download the newly created Offline area with all updates/edits.  I tested this by re-creating before syncing edits from the field device as well as after.  Neither lost any data.
As always, can be risky and normally test with a copy of the map/data, but to be safe, would also coordinate a sync with all users first just to be safe.
R_
