Multiline textbox won't move up when typing longer texts resulting in text getting covered by keyboard
409
04-21-2026 08:32 AM
Magnell
Hello!
On both iOS and Android multiline textboxes won't "move up" as I type longer texts. This results is that the text getting covered by the keyboard. Is this a known problem, and is there a solution?
I had some screen shots but could not find a way to upload images.
David_McRitchie
Hey Magnell,
I believe this crept in one of the more recent updates. The behaviour has been flagged under BUG-000180845.
If you raise a support case with your Esri Software provider they can attach this to your account so that you can track it on MyEsri.
Hope that helps,
David
Esri UK -Technical Support Analyst
Magnell
Hello again and thanks for the answer!
