major BUG: app is crashing after enabling tracks (version 23.1.0 build 1402)
2606
13
02-23-2023 06:55 AM
CollinKleiboer
In version 23.1.0 (build 1402) we discovered a major bug. After enabling the tracks, the app crashes and keeps crashing. Please fix ASAP!!!
Part of the logging:
Thu Feb 23 15:40:43 GMT+01:00 2023 : [APP LIFECYCLE] - Main Activity destroyed
Thu Feb 23 15:40:43 GMT+01:00 2023 : [URLSCHEME] - Updating content uri handler: j5.i3@22d3bc8 to null
Thu Feb 23 15:40:43 GMT+01:00 2023 : [APP LIFECYCLE] - Application asked to trim memory, level :: 20
Thu Feb 23 15:40:43 GMT+01:00 2023 : [APP LIFECYCLE] - Main Activity paused
Thu Feb 23 15:40:43 GMT+01:00 2023 : [DEBUG (error)] - Uncaught exception!
com.esri.arcgisruntime.ArcGISRuntimeException: Geodatabase field not found.: level_id is not a valid field.
at com.esri.arcgisruntime.internal.jni.CoreDictionary.nativeInsert(Native Method)
at com.
Thu Feb 23 15:40:43 GMT+01:00 2023 : [TRACKS] - ↓ additional info: delete temporary features failed: Parent job is Cancelling
Thu Feb 23 15:40:43 GMT+01:00 2023 : [TRACKS] - ↓ additional info: apply edits to tracks table failed: Parent job is Cancelling
Thu Feb 23 15:40:43 GMT+01:00 2023 : [TRACKS] - Failed to uploadTracks
Thu Feb 23 15:40:42 GMT+01:00 2023 : [TRACKS] - Ping tracking service
I've also attached the complete log-file.
Thanks in advance.
Regards,
Collin Kleiboer
JakeBrownMaps
@CollinKleiboer  - we'd like to take a look at your enterprise location feature class schema.  Can you email me at jakebrown@esri.com and we can loop you in with the team?
JakeBrownMaps
Hey @CollinKleiboer we are able to reproduce this issue with Enterprise 10.9.1 and will be working to resolve.
-Jake
CollinKleiboer
Hi Jake,
That sounds good!
Looking forward to see a solution 😉
Regards,
Collin.
ColinLawrence
Closing the loop here. We deployed a fix for this today which should be available momentarily in the google play store as Field Maps version 23.1.1. If others are running into this issue please ensure you update Field Maps.
Regards,
Colin
