Less than symbol not appearing in info element
450
06-03-2025 08:55 AM
GBayMnidooGamiiBiosphere
I'm using some info elements in my Field Maps form with description about qualifying the type of wetland based on a minimum amount of cover or other information. The greater than, less than or equal to characters are working fine, but the less than is only showing the code <2. Not sure if there's some kind of background code I can change or a character I can add before the symbol to get it to draw properly.
If noone else is having this issue, I will submit a support ticket.
KerriRasmussen
Hi @GBayMnidooGamiiBiosphere Thanks for bringing this up. I did some testing and I'm seeing the same behavior. I'm have logged the issue for the developers.
