Labeling in Field Maps does not update
926
09-08-2025 06:02 AM
GeorgeJonesRIGOV
hi all, i have entered values in the fields but they are not appearing to the way i like them. For instance, in the attachment you will see an attribute pair of (0 , 0) but that's not what i have entered in the field. Any advice on how to mitigate around this ? Other features have their attributes appear but for some reason only a few of them do.
thanks GJ
GeorgeJonesRIGOV
Never mind. Turns out i had duplicate , overlapping features so i deleted the one with 0,0 and it resolved itself!
MErikReedAugusta
MVP Regular Contributor
That sounds like possibly some sort of caching issue and/or a script failing to fire.
Can you share your labeling code?
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
GeorgeJonesRIGOV
