Is it possible to show attribute data instead of lat/long when users select records in Field Maps?
771
08-10-2023 02:42 PM
AngelynDavis
We are working on a new field map for an asset inspection process that allows users to edit attribute data with a custom form. When a user selects records from the map, is there a way to show specific attribute data instead of the lat/long coordinates? We would like the asset serial number to display instead of the coordinates.
marksm_macomb
I am not sure about how to remove the coordinates, but you can add attribute data to the pop-up title and it will show up in that list.
In Map Viewer Classic:
In New Map Viewer:
