Invalid barcodes scanned on Android 25.2.3
5477
12
10-13-2025 06:09 AM
NicolasGIS
Honored Contributor
Hello,
Since our workers migrated to Field Maps 25.2.3 on android, barcodes are not properly scanned.
The very same barcode is decoded with different values each time it is scanned. Here are few examples from 10 different scans in a row of the same barcode:
The barcode looks like the following:
So 5117 is the correct value.
Reproducible on multiple android devices. My example was done with a Galaxy Tab S9 fairly recent.
On IOS, the same barcode is properly decoded on IOS.
Anybody facing the same issue ?
Best regards,
Nicolas
NicolasGIS
Honored Contributor
Hi @ChrisDunn1,
Thanks for your quick reply: much appreciated.
Support was easily able to reproduce and logged the following BUG:
BUG-000182225 - Field Maps barcode scanning returns incorrect results for Code-39 on Androids.
I already escaladated it as it's a big issue for us.
Thanks
ChrisDunn1
Hi @NicolasGIS ,
I can reproduce the issue with the barcode that you shared, though it doesn't happen with any others that I create. Are you seeing the problem on a lot of different barcodes or just this one?
Also, do you know the type of encoding used for the barcode? I tried to recreate a fresh version with the same value but none of the encoding options I used looked exactly the same.
Chris
NicolasGIS
Honored Contributor
Hi @ChrisDunn1,
Thanks for having a look ! Much appreciated.
We are having this issue with all our barcodes that look more or less the same as the one  I posted. This is the reason why this issue is quite annoying.
Regarding the encoding I don't know. I can ask. What are the typical encodings protocol  ? Just to give them an example of what you expect ?
Nicolas
ChrisDunn1
The types of encoding might be something like Code-128, Code-39, Code-39 Full ASCII, MSI. If the people who created them aren't sure of the encoding, even knowing the tool that was used (an online generator, python, etc) would likely help.
NicolasGIS
Honored Contributor
Hi @ChrisDunn1
According to them this is Code-39. I kind of confirm it with an external barcode generator:
https://barcode.tec-it.com/en/Code39?data=*5117*
VS original bar code:
They look pretty much the same.
With the first bar code generated from the website above, I can reproduce the issue of ArcGIS Fields Maps not properly decoded it though it happens less often.
Does it help ?
Nicolas
NicolasGIS
Honored Contributor
Hi @ChrisDunn1,
Just found also this thread that looks very similar to our issue:
https://github.com/mrousavy/react-native-vision-camera/issues/2593
And it is also code-39 ...
ChrisDunn1
Thanks @NicolasGIS - that is super helpful. I'll pass this information onto the developers.
NicolasGIS
Honored Contributor
FYI @ChrisDunn1, there is also a more official android BUG related to Code-39:
https://issuetracker.google.com/issues/342003174
I guess it is not a good piece of news...
ChrisDunn1
Thanks for sharing that @NicolasGIS, I'll pass it along to our developers as well. Given that this may be an underlying issue that we can't do much about, how feasible is it for you to reprint barcodes using a different encoding? Ultimately that may be a quicker solution unfortunately.
NicolasGIS
Honored Contributor
Well, unfortunately, it is not possible. We have thousands of those spread around all the campus 😕
