If Arcade Expressions Fail- PLEASE allow data to still be submitted
1060
03-14-2023 07:18 AM
kmsmikrud
As noted by others posting recently and I also had an incident yesterday luckily a user was just testing, but if arcade expressions fail in the Field Maps form this does prevent a user from submitting that feature.
PLEASE modify the app to STILL ALLOW a feature to be submitted if a calculation is failing in the form.
Expressions are great, I tested in the Designer and worked great but we work offline and use the app for aerial surveys, so its an expensive fail if we can't collect data based on a calculation failing. The Field Maps Designer would also benefit from having an offline tester so folks KNOW which expressions also work offline.
The issue is also noted in this post.
I want to use the expressions, but need reliability in data collection.
Kathy
dgreenin
Any update on this?
