I'm getting error (Esri.ArcGISRuntime.ArcGISRuntimeException: SQLite constraint violation: SQLite: 19 Abort due to constraint violation)
1210
10-03-2024 08:22 AM
RyanDillingham
I'm getting this error (Esri.ArcGISRuntime.ArcGISRuntimeException: SQLite constraint violation: SQLite: 19
Abort due to constraint violation) using an offline map; and this error "Unable to Submit 1 or more attributes failed" using the same map online. I'm using a Trimble R2 GNSS and Esri Field Maps to collect.
Here was my general workflow:
  • I have been adding GPS metadata to my Esri fields so I can collect x,y,z in the field and get accuracy, etc.
  • I have been using Geoid 18 in Trimble Mobile Manager
  • I was collecting points this Monday with Geoid 18, everything worked well
  • We received a survey in Geoid 12B that we wanted to overlay our survey onto
  • So, in Trimble Mobile Manager, I changed the geoid, but it needed me to download Geoid 12B. I did that Monday night.
  • Using the same map and data collection feature, I tried the new Geoid 12B on Tuesday morning.
  • Using the map offline, I got this error "Unable to submit  com.esri.arcgisruntime.ArcGISRuntimeeException: SQLite constraint violation: SQLite: 19   Abort due to constraint violation."
  • Using the map online, I get this error " Unable to Submit 1 or more attributes failed."
I get the same errors when I switch back to Geoid 18. I can use my phone's GPS to collect points and autofill GPS metadata fields, but as soon as I switch to using Trimble R2, I get the errors again. I believe I can collect points using R2 and a point feature that does not have GPS metadata fields. I need to test further.
Any suggestions?
RyanDillingham
Problem Solved! It was indeed the name of the receiver that was causing the original errors. I made a new feature and added GNSS metadata as I usually do. Then I deleted the column for the receiver name, shared to web layer, added to my map, and was able to collect data again. Weird! So then I shortened the name of the receiver in the R2 settings to 2 letters and it worked. The default name was something like 20 asterisks (i.e. "******************************************"). I still don't understand why I was able to collect data including the name of the receiver before changing the Geoid. But for now I am back in business.
Thanks for the tips. I hope this helps others moving forward.
DanielFox1
Hi @RyanDillingham
If you are not on the newest version of the app I would try and update the app. In relation to the unable submit error you get please see this community post
Unable to submit error - 1 or more attributes failed.
This mentions collector but the solution should hopefully work for you also.
Have you had any schema changes before trying to submit changes?
RyanDillingham
Thanks for the suggestion, @DanielFox1.
I did ensure I am using the latest app version. It is up-to-date. Always a good reminder.
I also reviewed the link you sent. I didn't write any script, so I don't think that is the problem. But similar to @EvoAndreatti and @JosephGrossman , I am using an R2. I have also enabled GNSS metadata attributes. But, unlike @JosephGrossman , I do not think it is the name of the receiver that is the problem because I have been using the same receiver with GNSS attributes enabled for a while now. For me, the problem started when I changed the geoid settings in Trimble Mobile Manager.
Any other suggestions?
RyanDillingham
