Hyperlink to an entity on a feature layer
1266
08-18-2022 02:56 AM
MaozTreeCare
Hello,
The company i'm working for uses QR codes on trees in order to track them.
Each tree is a point on a map.
Is it possible to generate a hyperlink that will open the right tree on the map?
I would like to use this hyperlink to print on a QR code, or to build my own solution that will take an ID from the QR code and built the URL for it.
Is there any other solution?
Again: my main objective is to be able to scan a code on an actual tree and view it's data on the hosted layer.
** This does not have to use the fieldmap.
Thank you.
MarkBockenhauer
Yes, you can do this using an applink to open the map in field maps,  centering the map on the coordinate for the tree or using search for the tree's unique ID.    https://doc.arcgis.com/en/field-maps/ios/help/deploy-your-map.htm
MarkBockenhauer
DougBrowning
MVP Esteemed Contributor
I would consider 123 it has great barcode support.
