Hybrid Reference Layer (for Export) for offline use in FieldMaps
900
10-29-2025 04:07 PM
asiegel_HEC
I'm trying to create an item of Hybrid Reference Layer (for Export) in my organization's Enterprise Portal with credentials stored so it can added to a web map used in FieldMaps, offline configured. The issue I'm running into is that when I create a new item from the Hybrid Reference Layer (for Export), it just creates a tile layer for World_Basement_Export_v2:
What I want is this:
Anyone know what is going on? I've seen folks dealing with similar issue since 2021, so hope there is a solution out there somewhere. Appreciate any help you can provide!
JakeBrownMaps
hello @asiegel_HEC  - there is a bug with creating the new vector tile basemaps item and the style isn't properly set when you create the item in enterprise.  I have a "tips from the team" that will walk you through a python notebook that apply the fix.  This is a workaround until the root issue can be resolved.
TFTT video:
https://mediaspace.esri.com/playlist/dedicated/238781423/1_dthc36zr/1_4wpkj48u
Python notebook:
https://github.com/Esri/field-maps-scripts/blob/main/notebooks/Proxy%20Esri%20Basemaps%20for%20ArcGI...
If you have any questions feel free to email me at [email protected]
-Jake Brown
Field Maps Team - Product Engineer
asiegel_HEC
Hi Jake,
Thanks so much for the reply. I'm running through the notebook, but getting stuck on this part:
Error:
TypeError: 'Folder' object is not subscriptable
Do you know what is causing this? All my credentials are entered correctly.
joycxjc
Any updates or luck with this? Encountering this same issue now 😕
joycxjc
Update: I'm using ArcGIS Pro 3.7 and Enterprise 11.5. I needed to change a line of code to accommodate updates.
Replace: folder_titles = [folder["title"] for folder in gis_ent.users.me.folders]
With: folder_titles = [folder.name for folder in gis_ent.users.me.folders]
