Hi! My map has the below layers:
- Tanks (Layer)
- Inspections (Table)
I have a form set up for where inspections can be performed. Inside the Tanks layer, there is a "Conformance" field. I need the inspection form to update this related field.
I've tried the below code. All have been no bueno.
//test 1, object is immutable error
var tank = First(FeatureSetByRelationshipName($feature, "Tank"))
tank.Conformance = "success"
//test 2, object is immutable error
portal = Portal('https://xyz.maps.arcgis.com')
var gid = "{c33d5753-8219-4c55-9eg5-0d1b41c21104}"
var tank = First(Filter(FeatureSetByPortalItem(portal, '43ebf67a212448c9b57888562490093b', 0, ['*']), 'GlobalID = @gid'));
//test 3, works as att rule, not as arcade code in field maps
return {
'edit': [{
'className': 'Tanks',
'updates': [{
'globalID': $feature.tank_gid,
'attributes': {
'Conformance ': "success"
Any help would be greatly appreciated. I've been stuck on this for days. Unfortunately, attribute rules will not be able to be used due to how the sharing of the data will need to be set up.
