Having a child field reference a parent field in FieldMaps
334
4 weeks ago
WilliamBanker-Hix
Hello, this is likely an extremely simple question but what would be the best method to reference a parent field automatically when entering data in a child field for a related record.
For instance, we are using field maps to create a map that has a well locations points layer (Parent Field) on it and each well has a history of water levels (Child Field) associated with it via a relationship class. The relationship class is a 1 to 1 using their global IDs. The water levels need to have a "reference point" filled in to enter the data. The reference point is a field on the well location record that will never change.Currently, when entering a new water level, you have to manually enter that reference point, which is a good way to get transcription errors in the field.
What is the best method to automatically populate the reference point field in my water level form? Should I use an Arcade/python script to do it, or is there some other method in Field Maps or ArcGIS Pro itself?
Thanks again for any help!
ChristopherCounsell
MVP Frequent Contributor
If you have created a relationship class, publish as a layer, you should be able to add related records directly against the parent.
If you have this set up, you can create a form and use FeatureSet to call upon the related feature field and calculate the field automatically. Examples in here:
https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/arcgis-field-maps-get-started-wi...
WilliamBanker-Hix
Ill give it a shot and get back to you on if that works! Thank you very much!
