HI All,
I tested two different sets of Field Maps at a Geodetic Station:
Map 1
Map 2
For both maps, I used a location profile set to WGS_1984_(ITRF08)_To_NAD_1983_2011. And the NTRIP Setting set to Local Network, Mount Point: RTXM_34_NAD83(2011), Geoid: GEOID18(Conus). When collecting points at the Geodetic Station, both maps recorded locations approximately 1.5 meters off from the geodetic station. When collecting points without a location profile, although Field Maps generated a location profile warning, the collected points were in much closer proximity to the actual station location. Any suggestion on what I am doing wrong.
Keep in mind the Mobile Manager Status & Point Coordinates without a Location Profile where the same and they were in the same proximity of the station. 😕 should I let my field worker collect data in this unrecommended practice? Feels wrong
Oh, my device is Trimble R2. 5.48 Firmware ...I guess I can't update the firmware since our warranty is expired
Since you use WMAS basemap in both scenarios the GNSS should be transformed to WMAS. Your location profile will now depend on the coordinate system of the GNSS corrections. So, find out exactly what this mount point is serving. I am guessing that the GNSS corrections are already transformed that is why the measurements are correct without location profile.
@becyr Does the transformation you mentioned have a "~" in front of it? That indicates it's going in reverse, from NAD 1983 2011 to WGS 84. Without that, it's transforming from WGS 84 to NAD 83 2011. It should be "~WGS_1984_(ITRF08)_To_NAD_1983_2011".
In Field Maps location profile, GNSS Coordinate System should be set to "GCS NAD 1983 2011" (code 6318). Map coordinate system set to "WGS 1984 Web Mercator Auxilliary Sphere" (code 3857).
If the output reference frame in Mobile Manager is set to NAD83(2011) EPOCH 2010, this setup should work.
@Y_Chau Yes, I have the Datum Transformation set as that. I have tired deleting both applications and starting fresh. I have tried setting the location profile zoom level to the county level & greater extent. But nothing works🤔 . My position status is RTKFixed and Geoid18(Conus) Played around with CMRx, RTCM, CRM_Plus
Depending if you've updated to the new version of Field Maps 25.2 or not, you may have to reconfigure your receiver. I've posted the new workflow link here New TMM x FM Connection Workflow
