Global variables in Field Maps?
1091
05-04-2023 05:46 PM
DanielCardenas_G2
Hi all, I'm new to Field Maps, and wondering how do I define global variables that can be used by Arcade Expressions across form inputs? For example, how do I create an array to be used in an Expression in "textfield_1" and access the same array with a different function in "textfield_2"?
IngridHogle
I have this same question. @DanielCardenas_G2, if you ever found an answer or a workaround, would you be willing to share?
