Geodatabase item not found
1159
08-20-2023 01:24 AM
TobyChapman
I have a fieldmap app which I have setup with a related table.
Everything appears to work fine until I come to submitting a new record in the related table.  When I try to submit I receive the following error:
"error :Geodatabase Item not found"
I have tried looking through other posts with this error and they all center around the use of Android devices or issues with filters.
I am using an IOS device and the fieldmap app is version 23.2.3
I don't have any filters on.
I setup the related table in ArcPro and published the map.
Does anyone know what is causing this error?
JoabelBarbieri
Same here on Android.
