Generic 10837 General geodatabase error.
3494
04-01-2024 12:03 PM
TommyJackson
In ArcGIS server Manager, I'm getting the log Code 10837, General geodatabase error, from multiple .MapServer features. The Code is only thrown when the feature is used in Field Maps, not in ArcMap, Pro or any of the Portal Map Viewers. Any idea what can be causing this?
ChristopherCounsell
MVP Frequent Contributor
What version? Some users talking about a defect with query statistics that was patched/fixed:
https://community.esri.com/t5/arcgis-enterprise-questions/demystify-server-for-arcgis-log-codes/td-p...
https://support.esri.com/en-us/bug/the-map-service-outstat-fails-for-the-sdo-geometry-stor-bug-00014...
It's a generic error, so could otherwise be something that's not supported. Would need a more detailed logs from Server or Field Maps (particularly errors or unexpected behaviour).
IngridHogle
Did you ever get this answered or resolved, @TommyJackson ? We are experiencing the same issue in Enterprise 11.1, but only for one feature service. I would love to resolve this.
PhilippeChesselVdG
We do have the same exact error for some  Feature Services in Edit mode.
It is tagged as SEVERE on the ArcGIS Server Manager Logs
As it is tagged SEVERE , how to troubleshoot the reason behind ?
We had same errors , in 10.8.1 fully patched, and 10.9.1 fully patched
TommyJackson
I think it had to do with the feature having some kind of definition or sql query, usually in Field Maps. I gave up on trying to eliminate the error because it doesn't show any performance issue, just the code in the log.
