I have a rooms dataset that I've added LEVEL_ID and NAME_SHORT fields to per the Indoors model. This is a map service on our GIS Server. I've added these to an AGOL map and named the layer "Levels." I also have a buildings footprints service that I've named "Facilities." I am not seeing the floor picker in Field Maps. I've tried publishing this as both map and feature services, and still can't see the floor picker. Is there other setup I need to do in order to utilize the floor picker?
I found a solution to this issue. Instead of setting the lower floors with negative numbers, I made them positive. We only have a few facilities that have a 3rd floor (vertical_order 2) so level -1 becomes vertical_order 3, level -2 becomes vertical_order 4, etc. So now the default floor plan that comes up in Field Maps is the ground floor, vertical_order 0. But this also puts the floors out of order in the floor picker, because I'm seeing the highest numbers first, and the ground floor is at the bottom.
We're seeing a similar issue with the floor picker not being shown even though we are using the same service we use in our indoors apps that contains indoors data model compliant facilities, levels and units layers. The service works in our Indoors apps but in Field Maps the floor picker is no longer shown. The layer is pulled in as a map image layer.
Are you running the most recent version of Field Maps (20.2.0)? We saw similar issues with older releases of Field Maps however they seemed to be resolved with the most recent production release.
