Fieldmaps not reflecting changes to related table
896
02-13-2023 09:18 AM
ZhongmingAn
I have been trying to make changes to some related tables. I think things are working but once I click away from the selected feature, and then select it again, all the changes I just made will revert back to previous values but if I go to AGOL and select the same feature, the changes seem to be reflected there. If I give it a few minutes and exit Fieldmaps completely when the map is open and then reopen the app, usually the changes are there.
Wonder if anyone encountered this issue before and what might be a solution.
Thanks!
