FieldMaps crashes when selecting date on iPhone
1492
5
04-18-2025 07:36 AM
JamesBedortha
FieldMaps crashes when selecting date on iPhone. I tried it on Android and it works just fine. Not sure what is going on. Everything else works. Any ideas?
Faiez
Hi!
The date, the creator, the edit date, object ID and more fields generate by Field Map itself. So, you do not need to add these field when customizing your Field Map form.
JamesBedortha
Well, the date can be different than the then when it generated, so I would still need a date field.
Faiez
ColinLawrence
To clarify, did you add the date field when creating the Form, or is it an existing date field from the geodatabase? What is the date formatting? Thanks!
Regards,
Colin
JamesBedortha
It is an existing date field from the geodatabase. format is mm/dd/yyyy time
