Field Maps to Google Maps Error
1089
02-15-2023 01:01 PM
JacquiMartin
Several times over the last few weeks, I have selected a polygon from Field Maps, and chosen to get directions using Google Maps only to have my end destination changed about half-way through my drive.  I only notice when the directions are contrary to where I know I should be headed - anyone have this problem or know how to fix?
ColinLawrence
Hi @JacquiMartin ,
Is this still happening for you? What type of device are you using? Are you saying that the destination/location is changed in Google Maps after starting navigation? Are you staying in Google Maps after starting the navigation? Field Maps should only pass coordinates to Google Maps which would then handle things from there so im curious as to what might be happening.
Regards,
Colin
Regards,
Colin
