Field Maps Task Layout Buttons Not Appearing on Mobile (Resolved)
91
3 weeks ago
Vannndy
Hello all,
I am working with the Task Layer in FM to create an application where our field team can fill out many different surveys through one task layer, depending on the item's equipment type. I created a test web map with an existing feature layer that I added the Task Layer to. (I used standard configurations when enabling the task layer)
Now in testing when the status is "In Progress" the mobile view does not show the survey button (An integration layout element that links to the appropriate survey) I created in the Layout using FM Designer. I have customized the other views to our needs and all of the buttons in those layouts seem to be appearing correctly in the mobile view but my survey button is just not showing up.
I created a custom arcade script for this button and when using the arcade editor, I did not have any errors.
I do not think this would cause an error since all of my other layouts are working, but I am using a Google Pixel Tablet emulator through Android Studio to conduct my testing.
RESOLVED: I am not sure what exactly changed but after removing the button and adding it back multiple times, removing the script and readding it too, the button finally seemed to appear and is working properly!
