Field Maps Designer
618
11-06-2023 04:05 AM
wilbanrw
I am building a field maps form for data collection and added about 15 calculated expressions to different fields but now all of them are gone. In the form, the field still shows </> Calculated but when you select it(or any field) then click the cog next  to calculated expression none of my expressions are there.  I still have one I created in the editable expressions but that is it. I save regularly and worked on the form over a few days. The calculations were present after opening the form for the first few days. I can rebuild them but I fear if it happened once it will happen again..
Has anyone else had there expressions disappear after creating them?
