Field Maps and Integromat
1313
08-02-2022 03:08 PM
DEI
We're using Integromat to pull inspection data with the Field Maps module and then populate Google Sheets. We've noticed that on occasion all the data being collected doesn't make it into the spreadsheet (with no errors being reported from Integromat). The data seems fine in AGOL but doesn't reach the final destination. The issue appears to be most prevalent when multiple users are collecting data simultaneously. Can anyone offer an explanation as to why this would happen and/or has anyone else noticed this?
DEI
As a follow up, I've attached a PDF to help illustrate the issue
DEI
Based on reply from Integromat, the issue appears to be resolved by making adjustments to some filters within the scenario.
