Field Map: Related Data Table Links to another Data Layer
1006
11-25-2024 03:35 PM
ChristineAlevizos
Hello All,
Thank you for your time today.
I am using Field Maps and would like to add a link in the data layer table pop-up that will link to another data layer. I need this to happen in offline mode in the field map app.
Essentially the workflow will be:
1) open snare data layer point 2) open snare point related data table 3) if the snare was successful then show the link to a different data layer to enter a point.
Is this possible? I imagine it could just be as simple as a link- but I'm not sure what the link would be.
Thank you for your help!
ChristopherCounsell
MVP Frequent Contributor
You can create a link to open field maps and initiate capturing a feature. Parameters and examples here:
https://doc.arcgis.com/en/field-maps/latest/prepare-maps/deploy-your-map.htm#ESRI_SECTION1_F7DE2402B...
Theoretically you could construct the above url using arcade in field maps however I'm not sure if the URL to launch a map works from within the map itself.
You could also publish the layer with relationships between the three layers/tables. It wouldn't be a link, but the user could click through the relationship into the 2nd point layer.
