Field Map - all points disappear after adding filter
1639
04-05-2022 09:15 AM
by Anonymous User
Not applicable
We are using Enterprise 10.9.1.  We have a Field Map app.  The field map app displays several points. Therefore, we apply a filter to the feature layer to remove those points older than 4 weeks old that have a closed status. We have always used this filter, since the upgrade to 10.9.1 we have had an issue.
The issue is once I apply the filter, all of the points disappear.
Has anyone experienced this? Is this a bug? Thank you.
Annette
ABishop
MVP Alum
could possibly be a bug since you just upgraded... but quick questions... when do you apply the filter? In the map, web app, or feature class before publishing?
Amanda Bishop, GISP
by Anonymous User
Not applicable
I apply the filter in the classic map viewer.
Linde_Carmack
Yes, this is a bug logged in a couple environments.
BUG-000136699 - Field Maps on Android
BUG-000121972 - Collector on iOS
We have the same problem and we're on Field Maps on iOS. Here's a post a colleague made about it a while ago: https://community.esri.com/t5/arcgis-field-maps-questions/layers-not-displaying-in-field-maps-when-f...
