The FeatureSet commands seem to have gone out again in the latest update to Field Maps. Not sure when but all my test maps that were working are now broken.
I am going Production on this now and at the last hour nothing is working.
My code works in the web map great so I do not think that is it.
But now in Field Maps all are Null or 0
Sample code
DesignLat {expression/expr6}
var sql = "PointID = '" + $feature.PointID + "'";
var tbl = Filter(FeatureSetByName($map,"Points", ["DesignLat"], false), sql);
var val
for (var row in tbl) {
val = row.DesignLat
return val
Using an iPad Pro with the latest
I really need this fixed since this project since I have a deadline.
Thanks for any help!
Solved! Go to Solution.
Yes I had tried that already but no.
I heard back from the Field Maps team and they are seeing the same thing so they confirmed it as a bug and are looking into it. They think it is something with field request messing up the SQL query.
Good news is offline my popup is super fast so I am ok for now. Online it is taking 5-6 seconds on a iPad Pro and 13 on a regular iPad.
thanks
Might be because the field used by where clause is not requested, could you test with ['CollectCoreSubset1', 'PointID']?
thanks
