Feature Reports for Field Maps
2438
03-28-2023 02:44 PM
JacobPearse
Is there any expectation for Feature Reports similar to what is available in Survey123 to be incorporated into Field Maps? The Feature Reports in Survey123 is a nice feature that would be beneficial if the same capabilities were included within the Field Maps application since sometimes Field Maps seems to be more applicable to other collection efforts.
Is it simple enough to just bring a feature layer information from Field Maps into Survey123 to generate reports if there is not any indication that this option may be introduced by ESRI?
DougBrowning
MVP Esteemed Contributor
Data driven pages in Pro can get you there.  Bit more setup but they can be pretty fancy.
ClayDonaldsonSWCA
You can in fact create a form that references a feature layer collected in field maps:
Select Feature services from "New Survey" in survey123 connect.
Then you can make reports off of that particular feature service. Though, I generally create a view layer of the specific layer I need and point it at that. You also can't have spaces in the layer name.
This isn't really documented anywhere by ESRI, but I have been successfully using this method to generate reports for field maps data for awhile now.
Tanner_Sorgenfrey
When I tried this, the photos submitted on field maps aren't recognized by survey123 or something because they aren't showing on the feature report
ClintonKollars
same issue here. Any shots I did from Survey123 into that Feature Service would show up in te report but the ones shot in Field Maps do not show up in the report. I can see the image in those shots when I click on the point on the map but yet they do not print to the PDF report. Any thoughts on this?
