Feature points not showing up in Field Apps on older Androids
659
04-14-2021 10:52 AM
Cori_Grainger
I am using Field Maps for a data collection exercise to update the attributes for existing points, but the symbology for the points is not coming up on all of the devices, particularly the older ones. You can see the basemap imagery and if you click in an area where points exist, you will get the pop-up showing the attributes, but you cannot see the point itself.
There are no issues with the newer devices, only the older devices. All devices being used meet the minimum specs for Field Maps. Is there a way to fix this issue?
