Editing Capabilities in Field Maps
545
08-05-2022 01:00 PM
BrittanyNeihaus
I am trying to publish a point feature layer from ArcGIS Pro, add to a web map in my 10.6.1 Portal and then use ArcGIS Field Maps to edit the attribute data in the field. Even though I had published and set editing capabilities in the Item Details page, I still cannot edit this layer in my ArcGIS Field Maps application. There is no option to check whether I am using Collector or Field Maps in the Item Details page as other communities have pointed out, probably due to the fact that the web application has not been installed on that Portal. Another coworker had successfully been able to edit their data using the same Portal so I'm not sure what I am doing wrong.
