Editing Attributes by Default not Polygons in Fieldmaps
1212
07-17-2022 08:15 AM
MattPitts
Hi There,
I have a map all setup in Fieldmaps on my Android phone and its all working as expected except when I select the polygon and want to edit it's attributes by hitting the edit button it takes me to the edit polygon rather than the attribute form.
Is there a way from forcing FieldMaps to take me to the form attributes as the default rather than automatically taking me to the map view and wanting me to edit the polygon???
kurdishbrwar
Greetings, I think if you include pictures showing the problem, it will be better to understand the problem, which I think is easy. Greetings.
RhettZufelt
MVP Notable Contributor
In iOS, if I select a polygon and hit the edit button, it takes me to the edit polygon in the map, and the edit form in the bottom of the map so I can edit either/both.  Sometimes, need to scroll the attribute form up so you can see it all.
R_
