Editable View Layer
1489
01-18-2021 04:16 AM
RonParis
I'm trying to add a view layer to a map in Map Viewer Beta, but Field Maps isn't recognising the layer as an "Editable Layer", instead it's just appearing as a "Reference Layer". The view layer has all editing enabled expect for "Delete".
This is something I can achieve using Collector.
Not sure if there are known bugs around this, but I believe this is something that should work with no issues.
TIA
by Anonymous User
Not applicable
I'm not able to reproduce this behavior. Could you share some more details such as the specific layer settings regarding editing, a screenshot of the behavior you are seeing in Field Maps, and anything else that could be relevant.
by Anonymous User
Not applicable
RonParis
Thanks for the reply Aaron and confirming it should work. I've just tried it on a different dataset and all is working as expected!
