Drive Time polygon
954
04-22-2025 06:21 AM
JimWooten
Can drive time polygons be used to create geofences in Field Maps?
Thanks.
Jim
DanielFox1
Hi @JimWooten
I think you should be able to do this you will need to set the layer up against the geofence.
Get started with geofences in ArcGIS Field Maps
DanielFox1
Hi @JimWooten
ColinLawrence
@JimWooten do you mind explaining more about your planned workflow? For example, how you are generating the drive times and where and how they might be used with Geofences? I am curious about the use case.
To answer your question, the layer just needs to be hosted in order to use it as  Geofence features.
Regards,
Colin
