Default value for multiple choice fields not working.
133
Monday
RickSteekelenburg
The new multiple choice field doesn't register a default value even when it was set when adding the field directly to the feature layer instead of the template.
It shows in the form but it doesn't do anything.
RickSteekelenburg
Nevermind, it's been a long day.
I was editing an existing feature instead of adding a new one and wondering why it didn't show.
Thank you for your time.
MErikReedAugusta
MVP Regular Contributor
By chance, do you have subtypes enabled on that feature class?  I haven't worked with the multiple choice fields, yet, but this problem catches me napping every once in a while when I'm doing schema updates on a feature class with subtypes.  I'll set the default value on the Fields view, without remembering that the Subtypes view has a completely separate default value, which is the one that actually matters.
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
Megan-Hendrick
Hi Rick,
One thing I would check is that the default value you are using matches the code of your multiple choice element. For example: If I wanted a default value of Steel Toes Boots and Safety Vest to be reflected in this multiple choice element (see screenshot below), I would set the default value to "boots,vest". Note that you need the comma delimiter (without a space), to match the case sensitivity, and to match the code not the label.
Let me know if you are still having issues!
RickSteekelenburg
