Hi -
I am migrating some workflows from Collector to Field Maps and I am running into issues with my callback URL parameters.
The workflow:
This worked very well with Collector and was simple to configure. With Field Maps, I am getting some weird errors, even though I am following the documentation on both Survey123 and Field Maps help pages.
If I use a URL formatted like below, I get an error when attempting to open Survey123 from the URL. The error is in Survey123 and says "Error Unpacking":
https://survey123.arcgis.app/?itemID=10242016ba5b4ab3883bf40bb8ae76fb&field:Ag_Guid={GlobalID }&callback=https://fieldmaps.arcgis.app /?referenceContext=open&itemID=6b34dffb1c0b41b3907c61a97d0b1e4a
This same error occurs when I modified the URL to be something like this:
https://survey123.arcgis.app/?itemID=10242016ba5b4ab3883bf40bb8ae76fb&field:Ag_Guid={GlobalID}&callback=https://fieldmaps.arcgis.app://?referenceContext=open&itemID=6b34dffb1c0b41b3907c61a97d0b1e4a
https://survey123.arcgis.app/?itemID=10242016ba5b4ab3883bf40bb8ae76fb&field:Ag_Guid={GlobalID}&callback=https://fieldmaps.arcgis.app//?referenceContext=open&itemID=6b34dffb1c0b41b3907c61a97d0b1e4a
If I use the callback URL without the referenceContext parameter included, the callback seems to work, but does display an on-screen error when returning to Field Maps; this happens with either of the formats below:
https://survey123.arcgis.app/?itemID=10242016ba5b4ab3883bf40bb8ae76fb&field:Ag_Guid={GlobalID }&callback=https://fieldmaps.arcgis.app ://?itemID=6b34dffb1c0b41b3907c61a97d0b1e4a
https://survey123.arcgis.app/?itemID=10242016ba5b4ab3883bf40bb8ae76fb&field:Ag_Guid={GlobalID }&callback=https://fieldmaps.arcgis.app /?itemID=6b34dffb1c0b41b3907c61a97d0b1e4a
Error:
I did check and the Survey123 data submits properly. I am returned to the proper map in Field Maps, but see this error each time.
Does anyone have advice on how to resolve this issue?
Thank you,
Hi Bryce - this isn't something I've looked into at all, so I do not know. Sorry!
This post really helped my troubleshooting...was having the same issue. Much appreciate you @Anonymous User . And thank you @erica_poisson for pursuing and even posting some examples.
Thank you for the examples @Anonymous User !
One of my surveyors has put a wrench in all of my URLs by having a Dell tablet that runs on Microsoft Operating system (all the rest use Ipads). There is no field maps app to download for this. Any ideas if a callback could work for a WebApp Builder? And if it might work, how would the callback be structured...?
Current workflow is
This particular surveyor is not the most tech savvy and hesitant to move from paper surveys to a digital platform. I am trying to make it as seamless as possible for her.
Thank you for any thoughts on this!
Jessica
Just wondering how pop-ups are being configured to include the URL with additional parameters. Is it stored in the attribute table? I believe pop-ups could be configured to link to surveys etc. in map viewer classic but I am unaware of how they can be included in map viewer (it's been a while since I've had to use URL parameters).
This article helped me when I was configuring the custom URLs to link Survey123 and Field Maps for my organization: https://doc.arcgis.com/en/survey123/reference/integratewithotherapps.htm
