Custom primary key for relationships?
1641
08-22-2022 12:37 PM
DamonBreen
Hi all,
I posted a few days ago about an issue I was having with related records in an arcade expression not evaluating correctly. I came to find out that the globalID (which I always use as my primary key) was not populating until after the submission of a feature, therefore affecting my sql statement to look into the related records. To fix this, I created a new primary key field and used that for my relationships. I then added this code:
var AllLeaks = FeatureSetByName($map,"Gas Leak")
var LeakCount = Count(AllLeaks);
var NewestLeak = First(OrderBy(AllLeaks,"LeakID DESC"));
if(LeakCount == 0){
return 1
} else {
return sum(NewestLeak.LeakID, 1);
... to make my own auto-incrementing key. The problem with this is, that if I have to go back into an already-submitted feature to edit something, it renumbers this LeakID, and the relationships are gone. Is there a way with Arcade that I can tell it to only evaluate this code on the creation of a new feature and not when updating it? or is there a better way of doing what I'm doing? I also tried to have it do a compare of the object ID of this feature to the newest feature to stop it from updating, but that doesn't seem to work. I would like to keep the end users from having to enter their own leak number if possible.
Damon
JohannesLindner
Check if there is already a LeakID. If so, just return that, essentially changing nothing.
if($feature.LeakID != null) {
    return $feature.LeakID
if(LeakCount == 0){
    return 1
Have a great day!
Johannes
JohannesLindner
if(LeakCount == 0){
    return 1
Have a great day!
Johannes
DamonBreen
Very weird, I thought I had tried this basically already with IsEmpty() and it did not work, but this in fact does work.
Thank you very much!
JohannesLindner
Also, not sure if that applies to FIeldMaps, but in an Enterprise GDB, you can create a database sequence and then call NextSequenceValue in Arcade instead of loading and ordering the whole featureset.
Have a great day!
Johannes
