Create new feature NOT at current GPS location
896
03-24-2026 02:26 PM
Pukawai
Using fieldmaps I often need to search for an existing feature and then create a new different feature on top of it. While this is doable if I am standing near the existing feature and then adjust the location to snap to the existing feature, it is totally impractical if I am elsewhere since touching the "+" sign immediately pans the map to the current GPS location. Is there any way I can get FieldMaps to just put the location circle in the center of my current extents?
gisadministrator_lpud
You can check with Esri AI Chatbot, (I just did), it does allow it. You will need to enable it through Field Maps Designer - for "manual location" instead of auto-adding a feature at your GPS location! I personally manage all of my edits on ArcGIS Pro being in-office.
Pukawai
Thank you for this! It is a solution, but I would have expected to find a setting like that in Fieldmaps where the user can control it. I too manage my edits in the office but am stuck with using ArcMap, so the info for edits is much easier to get if I make other people to enter it!
RhettZufelt
MVP Notable Contributor
Yes, that gets very annoying when you are panned to the area you want to make a point and it pans you back to your GPS position.
That setting is controlled in Field Maps designer App Settings:
R_
