Create direct link to add related records in Field Maps
4429
11
04-17-2024 07:23 AM
ajohnson_wsb
I'm looking to simplify the way that users have to add related records in Field Maps. I know that on the parent asset, a user can click the related link at the bottom and then click Add, etc. but I am looking to give users a "button" or something so that they can directly open a new related record. The goal is to limit how many times users have to click through boxes when adding new related records
At the Dev Summit last month, Esri showed a way to do this with Arcade and HTML but the presentation missed pieces in the demo that showed all of the code in order to replicate. Recording of the presentation is below:
https://registration.esri.com/flow/esri/24epcdev/deveventportal/page/detailed-agenda/session/1699036...
If anyone has successfully done this please let me know. Thank you!
LeighStarr
I am getting an error: "The specified foreign key field couldn't be found".
I am a little confused... there isn't anything pointing to the child in the relationship.  Everything points to the parent, including the source URL.  I would have thought that the foreign key would point to the child, but the comments clearly state parent...
For the relate, both are branch versioned, with the Primary Key of the Parent feature class: 'GlobalID', and the Foreign key in related feature class: 'CAB_GUIID'
With the parent primary key as 'GlobalID' my entry into the expression builder is:
var featureID = Replace(Replace($feature.GlobalID, "{", ""), "}", "")  //GlobalID field of parent asset
var foreignKeyField = 'GlobalID';   //GlobalID field of parent asset
On a somewhat related note, if I have multiple relates, how would it know which one to add?
What am I missing here?
dhertel
@LeighStarr Did you ever find an answer to this question? I also have multiple tables relating to my parent feature class, and I don't understand how this expression is supposed to know how to select any of the child tables to create a new record in. The URL generated by the expression doesn't do anything for me. I've tried using the specific FeatureID url's for for the related table, but that doesn't work either.
