Coordinate Systems for Web Map and Data to use in Field Maps
8131
11
03-27-2024 03:58 AM
GISUSER6
Hello. If I wanted to collect data in a local coordinate system (CS), would I create my data in the local CS and create a custom basemap in that same CS? I am using a Trimble DA2 reiciever to collect data. For the location profile  in Field Maps, would I always chose NAD 1983 2011 as my GNSS CS and then the local CS as my map CS?
GISUSER6
I did some more testing.
Set up #1:
Using the custom basemap in the local county coordinate system, then publishing the hosted feature service in that same local county coordinate system. The GNSS input is always NAD 1983 (2011).
Transformation is NAD_1983_HARN_To_NAD_1983_2011 in Esri Field Maps.
Set up #2:
Data, custom basemap, and GNSS output is all in NAD 1983 (2011).
No transformation is occurring in field maps, but then post-processing of the data occurs by projecting the data to the local county coordinate system in ArcGIS Pro.
I tested on two devices with varying accuracy levels. One was an Eos Arrow Gold CM Receiver. I actually ended up having more accurate results with the Set Up #1 with the hosted feature service being in the local county coordinate system than it being in NAD 1983 (2011) for Z values. X and Y were pretty comparable. With this data in the local county coordinate system already, it seems to make more sense to stick with set up #1. Is my thought process off on this?
ColinLawrence
I agree with this; I believe you are on the right track. I cant comment too much on the Z value results though as I have less experience in the area of vertical datums.
Regards,
Colin
