calculated expression is working fine while testing but not populating in fields
1404
08-25-2022 04:49 PM
SajoJose
forms for every calculated expression is working fine while testing but not populating in fields  while populating
for more insight This was the script getting result on testing but not on inputting data in form
var mdm1 = [1,1,2,2,3,3,3,5];
var mdm2 = [1,1,1,2,2,2,2,3];
var mdm;
if (DomainName($feature,"Area_Charectristics") == "Open Forest")
{ mdm=mdm1;}
if (DomainName($feature,"Area_Charectristics") == "Open Grassland")
{ mdm=mdm2;}
if ($feature.RAINFALL=="0"){
return mdm[0];
if ($feature.RAINFALL=="1"){
return mdm[1];
if ($feature.RAINFALL=="2"){
return mdm[2];
if ($feature.RAINFALL=="3"){
return mdm[3];
if ($feature.RAINFALL=="4"){
return mdm[4];
if ($feature.RAINFALL=="5"){
return mdm[5];
if ($feature.RAINFALL=="6"){
return mdm[6];
if ($feature.RAINFALL=="7"){
return mdm[7];
Tags (3)
JohannesLindner
You're comparing $feature.RAINFALL to a string value. Is the field really a string field?
Also, you can shorten that script like so:
var mdm;
{ mdm=mdm1;}
{ mdm=mdm2;}
var index = Number($feature.RAINFALL);
return mdm[index]
Have a great day!
Johannes
SajoJose
Thanks for the response
$feature.RAILFALL is a code value
This is also returns value while testing but no updating while inputting through forms
