BufferGeodetic() causing field maps to fail
1215
01-10-2024 12:00 PM
DavidStephen-Tammuz
I am using BufferGeodetic() in an arcade expression since our maps are in Web Mercator. When creating line features in Field Maps, the program crashes after adding a single point (i.e. I press ‘Add Point’ once and everything freezes). The Field Map Troubleshooting Log showed the following messages:
When I changed the expression to use Buffer() instead of BufferGeodetic(), I was able to digitize lines in field maps without any issues, though it produces inaccurate results.
I was wondering if anyone had run into a similar issue and if there was a way around it without reprojecting our data. The issue only seems to occur with the geodetic buffer, and not with geodetic distance/length functions.
Thanks!
DanielFox1
Hi @DavidStephen-Tammuz
I am sorry to hear that you are having this issue.
This matter has been identified as a bug BUG-000164493
https://support.esri.com/pt-br/bug/using-the-buffergeodetic-arcade-function-on-a-line-laye-bug-00016...
