Automatically include current weather conditions for new features
1068
07-13-2022 04:51 PM
jeffj
Someone at the showcase today asked about having Field Maps automatically include the current weather conditions for newly created features. Here's what I came up with.
Add the service Current Weather and Wind Station Data to your map.
Add a text field to your layer to store the weather conditions.
Using Field Maps web, create a calculated expression for the field and use this Arcade expression:
var searchArea = Buffer($feature, 25, 'miles')
var stations = Contains(searchArea, FeatureSetByName($map, 'Stations'))
var closest = null
var minDistance = Infinity
for (var next in stations) {
  var nextDistance = Distance($feature, next)
  if (nextDistance < minDistance) {
      closest = next
      minDistance = nextDistance
if (IsEmpty(closest)) {
    return null
return Text(closest['TEMP'], '#') + 'º F, ' + closest['SKY_CONDTN'] + ', Wind: ' + closest['WIND_SPEED'] + 'km/h'
There are a number of other attributes with interesting information so feel free to customize as you see fit.
AlexVideka
This is awesome Jeff! Do you know whether this would need to be modified to populate a field in a related table (insepction table) connected to the feature class?
We'd be adding a new related record (eg daily inspection) and not a new feature in this use case.
DarinVanDeBerg
Hi Alex,
Were you able to find any information about your question on the related table?  I am looking for the exact same thing!  Thank you,
Darin
AlexVideka
Hi Darin,
Unfortunately, I have not yet had a chance to test out Jeff's solution on related tables. This was a 'nice to have' improvement and has been backlogged for the time being. If you are able to get this going, I'd love to know more!
Alex
