Attribute Rules and not loading layers
998
09-11-2025 02:35 PM
Ona_Tim
I have created a Field map app to help in road ratings. I created a project in pro with 2 layers and exported to portal.  On the WISLR Streets I have an attribute rule to update the paser date when the Road rating is updated
When I open it in field maps the layers fail to load.
The error is as follows:
Domain: com.esri.arcgis.runtime.error
Code: 7018
Description: Arcade expression is invalid.
I have included a screenshot of the attribute rule.
This app will work in portal with no issues.
Thank you for any help
Ona_Tim
Here is an update.
Since the Field maps update to 25.2 this has now been working.
gis_KIWI4
MVP Regular Contributor
@Ona_Tim - Use a calculated expression in the FieldMaps Designer to calculate the now() in the attribute. Remove the attribute rules.
The calculated fields are a more robust method of calculating fields within fieldmaps.
https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/common-calculated-expressions-fo...
Ona_Tim
Here is an update.
