Hello GIS friends,
I'm trying to open Field Maps app on an android phone and when I sign in I get this error.
No available apps
There are no apps currently configured on this device that your organization allows to open this content. Please ensure you are signed in with your work or school account to your managed apps or contact your organization's support team.
However, I'm able to sign in from other devices using the same credentials.
I did a few things but I'm still not having luck.
Cleared cache on the phone
uninstalled - reinstalled Field Maps
Checked for software updates on the phone
Please help.
Thank you,
Abi
@ColinLawrence I have emailed you. Thank you for allowing me to do so.
Hello All ,
I also encountered same issue on my Android device. Able to login into ArcGIS Online with Chrome default browser however when I set Edge as default browser ended up with same issue. Any findings.
@ColinLawrence , I can reproduce on my device . Please let me know if any details required.
No available apps
Hi @AparnaSunki , what are the specs of your device that you see this problem on? Please also let me know the version of the Edge Browser. Thanks!
Hi @ColinLawrence ,
Here are the details
Edge Browser version : 132.0.2957.129
Device Specs
Android Version : 14
Processor -Samsung Exynos 1280 S5E8825
What is the model of this Samsung phone/tablet?
@AparnaSunki @ColinLawrence - I would change the default browser to sign in then. Colin's resolution worked for me.
Hello
I had a very similar problem trying to help my colleague who could not sign in to Field Maps (portal or AGOL).
The solution was to install a browser (Chrome) to the work profile on her Samsung Galaxy. Previously there was no browser in her work profile (but there was in her personal profile).
So, if you are unable to sign in to Field Maps I'd suggest ensuring that a web browser is installed in the same profile as Field Maps.
Good luck, Stephen
