ArcGIS Field Maps & Pull Data
6819
10
02-16-2022 10:29 AM
JD1016
Hello Everyone,
I've just started down my journey of employing ArcGIS Field Maps for our meter inventory crew.  I've been able to successfully connect notifications via Integromat and include barcoding functions.  Configuring webhooks in Integromat was challenging but it is working quite well.  I've employed both the webhook and barcode functionality that was present in our Survey123 apps successfully but there is one component that seems to elude me that I would like to use in Field Maps.  Finally my question...
Can ArcGIS Field Maps use the "pull data" function to populate fields based on a barcode scan event from a previous question/field?
Thank you and have a great day!
Jeff
JD1016
Aaron...can I collect data in the field using ArcGIS Field Maps AND pass this same information to fill out corresponding form data within Survey123?
If that's the case, I could theoretically use Survey123's Create Report function in Integromat to deliver email attachments of the forms to users.
