Arcade referencing original feature broken after update
6379
22
10-01-2025 07:09 AM
jmaxwell_braun
We are getting errors for fields with Arcade calculated attributes after the Field Maps 2025.2 update. It appears to only affect expressions that use the $originalFeature variable. The error message is vague: "10 attributes failed". Was there anything in the latest update that would cause this? Thanks
Edit: Esri has determined this is a bug. BUG-000179854, Description: The $originalFeature function fails when creating a new feature in ArcGIS Field Maps version 25.2, but editing the existing feature is successful.
CodyPatterson
MVP Regular Contributor
Hey @jmaxwell_braun
Would it be possible to show a bit of the code? There may have been a depreciation that is causing this.
Cody
jmaxwell_braun
Hi Cody, here's an example.
//sets value of calculated coordinate field to null only if the location of the point is edited
//if only attributes are edited, the coordinates remain the same
if(!IsEmpty($originalFeature))
  if(Geometry($originalFeature).x != Geometry($feature).x)
    return null
  else
    return $feature.UTM_X
else
DougMorgenthaler
@jmaxwell_braun can provide some additional information to help us understand the issue a bit more.
  • What platform(s) are you seeing this error?
  • Occurring while using connected map, offline, or both?
  • Is the expression failing only when updating an existing feature?
jmaxwell_braun
@DougMorgenthaler , it's happening on iOS with Field Maps logged into ArcGIS Online. Online only, have I have not tried offline. Seems to only happen when creating new features.
DougMorgenthaler
Thanks @jmaxwell_braun for the updated info.
IngridHogle
The calls just started coming in from staff that multiple Arcade expressions are failing for us after last night's update, and they cannot work as a result. 😞 I'm not sure what to do so I'm posting here in hopes of adding some urgency to this situation.
jmaxwell_braun
I opened Esri case number 04012489. For me it only affects certain expressions. For now I'm just disabling them so our field staff are able to work.
DougMorgenthaler
@IngridHogle can you please provide some additional details.
  • Are the expressions being used in a pop-up, form, or elsewhere?
  • Can you share examples of expressions that are failing?
IngridHogle
I was able to identify that for us, anyways, it is sloppy Arcade expressions I wrote in forms that are causing errors in Field Maps 25.2.0. These are of two varieties:
1. In one Arcade expression, I declared a variable twice (var BlahBlah = "this", then later var BlahBlah = "that"). This worked without errors in Field Maps 25.1.0, but failed in 25.2.0. Removing the second "var" statement, so it reads var BlahBlah = "this, then later BlahBlah = "that", fixes the issue.
2. In multiple Arcade expressions, I invoked $originalFeature without first using an If statement to make sure I was within $editcontext.editType =='UPDATE'. This worked without errors in Field Maps 25.1.0, but fails in 25.2.0. It makes logical sense to me that it would fail, since $originalFeature does not exist (there is no original feature) in the context of $editcontext.editType == 'INSERT'.
