Arcade Expression does not populate field
549
05-30-2025 01:58 PM
TimHayes3
In Field Maps Designer - Form, I have created an expression that if UPD_PERSON contains the letters "FFD" that the value in UPD_PERSON will get populated in UPDATE_BY.
I test it in Field Maps, make edits to a point, and the UPDATE_BY field stays empty.
Here is the calculated expression I added to UPDATE_BY field:
if (Find("FFD", $feature.UPD_PERSON) > -1) {
  return $feature.UPDATE_BY;
Can someone tell me what I need to do fix the expression?
On a separate note, I have a UPDATE_DATE field that gets autopopulated with the current date using the Arcade expression Now (). No problems with this expression.
Thank you.
TimHayes3
I figured this out:
var DEPT1 = $feature.UPD_PERSON;
if (Find("FFD",DEPT1,0)>-1)
{return $feature.UPD_PERSON;}
Now it works!
TimHayes3
I figured this out:
Now it works!
