After ArcGIS Online Update Last Night, Field Maps No Longer Will Execute My Arcade Expressions
1156
10-26-2023 02:03 PM
ArmstKP
I am getting this error:
Error Domain=com.esri.arcgis.runtime.error Code=15 "Invalid call." UserInfo={NSLocalizedFailureReason=Unable to evaluate arcade expression. Evaluation_error_code::unexpected_null_value Line :11, NSLocalizedDescription=Invalid call., Additional Message=Unable to evaluate arcade expression. Evaluation_error_code::unexpected_null_value Line :11}
Works fine in the Map Viewer popup, but not in Field Maps.
RebeccaRichman
Hi @ArmstKP,
Thank you for letting us know about this! Could you log a case with Support about this: https://support.esri.com/en-us/products/arcgis-online?
An analyst can then get more information and help resolve the issue.
Thank you!
Rebecca
KevinBurke
Hi @ArmstKP
Thank you for reporting this issue.
Can you please share more details about the Arcade expressions you've configured for Field Maps and how they are no longer working?
If needed, are you able to share a web map with us to reproduce the issue?
-Kevin
ArmstKP
@KevinBurke I sent you a DM.
