Able to View/Edit/Add Records in one Related Table but Not Another
1193
08-21-2024 10:36 AM
ThomasBucher
I am trying to configure a Field Map application to be used for road inspections. I have a feature service that holds a polyline layer of roads that is related to two separate tables, one for inspection results and one for deficiencies.
After setting up my Field Map, I'm able to view, edit, and add records to the deficiency tables but no records display from the inspection table and when I try to add a new record a pop-up appears saying "Unable to Create Feature".
Does anybody know what might be causing this issue? It seems odd that one related table works fine but the other does not.
HannesVogel
Hi @ThomasBucher , did you check the requirements for related records in Field Maps? Only 1:1 or 1:N (one to many) relations are allowed and not many to many. I don't know what cardinality you used.
ThomasBucher
Hi @HannesVogel, both relationships are 1:N, and I've ensure that the Related Types setting is set to All rather than Filtered.
HannesVogel
And you also used GlobalIDs and GUIDS as keys?
ThomasBucher
Yep, used the GlobalID of the parent and created GUID fields for the child tables.
