25.2.0 pop-up performance issues
6876
24
10-02-2025 03:06 AM
ChristopherCounsell
MVP Frequent Contributor
We are seeing significant lag for pop-ups:
  • Clicking on the web map spins for 5-10 seconds before showing any items
  • Items (layers/features in the pop-up list) are taking 5-20 seconds to load in the item list. The layers at the bottom of the map appear to be loading first, meaning the items at the top that previously appeared first are the last to load and significantly delayed
  • Selecting a feature from the item list then takes up to 10 seconds to display pop up content
For maps with ~5 active layers it's slowing things down.
For maps with ~20 active layers it's basically unusable.
Layers are rendering on the map fine. There's no decrease in map/network performance for the layers that we can see.
Same map in 25.1.0, pop-ups load basically immediately. Corroborated across 6+ maps and dozens of devices.
Anyone else seeing this or have suggestions?
Really wishing Field Maps got the 'classic' release treatment...
Cheers
Chris
MaxMolello
We are seeing similar performance problems. I'm not noticing layers loading from the bottom up, but overall performance is far slower. The basemap and layers take about 4x as long to load in the new app version. Popups will not load until the map and layers are fully done loading, so if you pan somewhere and click on something it takes well over 10 seconds for the pop up. If you pan somewhere and let everything load then the pop up is faster bit still slower than 25.1. It seems like Field Maps got the WAB to ExB experience, new features no one uses and new bugs and performance issues that affect everyone else. So much for pre-release testing.
ColinLawrence
Hey @ChristopherCounsell and others, if you have not done so already please log Support ticket for this so we can track the impact.
Also, I know you mentioned multiple devices but can you provide and example or most commonly used and its platform/version? Please also let me know if this is Portal or AGOL and some info about the types of layers in these maps.
Regards,
Colin
MaxMolello
Yes, we have a ticket open on this too already. We are seeing it on iPhone and Android in online maps, not offline areas. It doesn't seem to make a difference what the device is. We use Portal 11.3. This occurs on point, line, and polygon feature service layers.
ChristopherCounsell
Hi @ColinLawrence ,
Yes we have a support ticket.
  • ArcGIS Online
  • Hosted feature layer views
  • Polygons, polylines and point layers
  • Some maps have a lot of layers and features but it's occurring on one with just 7 layers, 5 enabled for pop-up, clicking on an area with 3 features at a zoomed in extent.
  • All layers in WGS84 web mercator
  • Occurring on maps with/without map level layer filters. Most views have an item level filter
  • Occurring on maps with tasks enabled
  • IPads and iPhones mostly. 18.6 or 18.7? iOS
There's a possibility it's an arcade expression in the pop-up itself when opening the individual feature. It's 5-10sec vs immediate when side by side to 25.1. We can live with that for now, it's the delayed list of layers/features to choose from that's really slowing things down.
Cheers
Chris
ColinLawrence
Thanks for these details @ChristopherCounsell . Just to clarify:
Its not only occurring on Task enabled maps, correct? A map could have been configured with Tasks ahead of the mobile release, so I just want to confirm the behavior is not restricted to those maps.
Any chance you can share a map with us? If so, share the map and layers to a Group and invite "arcgisfieldmaps". Please let me know if you do this so I can check this account.
Regards,
Colin
ChristopherCounsell
Not only on Task enabled maps. We had 6 maps (2 simpler with Tasks, 4 more complex but not Tasks)
The performance seems to have improved which suggests it was tied to some ArcGIS Online server-side issues.
However we did not see any issues whatsoever when comparing AGOL and 25.1 alongside 25.2 during the period. We tested 4 devices in the office and got widespread reports from the field explicitly for the users that updated.
Seeing unusual behaviour elsewhere today:
  1. Get loading icon and no form when creating a new feature from template. It's a very basic point layer.
  2. Form uses Arcade, has a mix of $originalfeature, edit mode = insert, if statements, GetUser($layer).username, now(). Using variables and accounting for if inserting or updating i.e. no original feature reference on insert. Worked fine in 25.1 and online.
  3. Remove the arcade, form starts working in 25.2
  4. Add the same arcade calculations back in, form continues to work in 25.2?
Suggests there was some temporary performance hiccup but there's no other indications e.g. everything worked fine on 25.1, ArcGIS Online, and 25.2 when interacting with the layer outside of creating a new feature.
Logs have one line in the logs but it's not super helpful
8/10/25, 2:44:07 pm [SNAPPING] NOT activating snapping because not editing any features yet or it's disabled
8/10/25, 2:44:07 pm [LOCATION] Stopping location provider
8/10/25, 2:44:07 pm [LOCATION] Unregistering request MainMapViewModelImpl
8/10/25, 2:44:04 pm [ARCADE] FeatureFormViewModel.evaluateExpressionsAndUpdateUI() - Cancelled, not updating FeatureFormItems
8/10/25, 2:44:04 pm [SNAPPING] NOT activating snapping because not editing any features yet or it's disabled
8/10/25, 2:43:34 pm [REFRESH TASK] Cancelled refresh task request for identifier: com.esri.fieldmaps.task-list
8/10/25, 2:43:31 pm [REFRESH TASK] Successfully scheduled refresh task for identifier: com.esri.fieldmaps.task-list
8/10/25, 2:43:29 pm [SNAPPING] NOT activating snapping because not editing any features yet or it's disabled
8/10/25, 2:43:29 pm [AUTHENTICATION] Removing Handler: Cancel Handler: Load Map Items-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
8/10/25, 2:43:28 pm [TASKS] Notification permission denied: wasPreviouslyDenied - true
8/10/25, 2:43:28 pm [LOCATION] Starting location provider
8/10/25, 2:43:28 pm [LOCATION] Registering request MainMapViewModelImpl
8/10/25, 2:43:28 pm [TASKS] Created tasks capability
8/10/25, 2:43:28 pm [AUTHENTICATION] Removing Handler: Cancel Handler: Load Map-AB3B726C-BB72-442B-AFB4-F3AD60BD19A8
8/10/25, 2:43:28 pm [LOADING] Loaded map xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
8/10/25, 2:43:28 pm [MAP TOOLS] Not creating IPS, no indoor positioning definition
8/10/25, 2:43:28 pm [SPATIAL UNIT] Not creating SpatialUnitCapability
8/10/25, 2:43:28 pm [GEOTRIGGERS] Geotrigger count: 0
8/10/25, 2:43:22 pm [AUTHENTICATION] Adding Handler: Cancel Handler: Load Map Items-1CDA0110-5B15-415D-A944-D4D355EDE675
8/10/25, 2:43:21 pm [AUTHENTICATION] Adding Handler: Cancel Handler: Load Map-AB3B726C-BB72-442B-AFB4-F3AD60BD19A8
8/10/25, 2:43:07 pm [MAP] Failed to provide map: noMaps
8/10/25, 2:43:03 pm [PORTAL] URL: https://www.arcgis.com Mode: AGOL Version: 2025.2.0
ColinLawrence
@ChristopherCounsell we have a bead on this popup performance with expressions and hope to have it addressed soon. Its not specific to Tasks maps, I was just unsure at the time last week.
Regarding the other unusual behavior. Do you know if you were on 25.2.0 or 25.2.1? A fix was applied for errors returning when using $originalFeature in the 25.2.1 patch release and im wondering if that is related to what you saw. Note: 25.2.2 was just released today so double check on that and make sure you are not having issues around this still. Thank you!
Regards,
Colin
IngridHogle
Our users are reporting the same issue - when tapping on the map, the list of features to load is slower and the opening of the popup of the selected item is slower. The lag time for us is not as bad as some have described above, but it is slower than 25.1.0. One user has noticed that it seems more difficult to tap on features than in 25.1.0 and has asked if the threshold has changed in terms of how close you need to tap to a feature.
GrantHoward1
I have users with the same issue and I test on my phone with Field Maps version 25.2.1 and we get no popup at all. Maybe we didn't wait long enough (but we waiting up to a minute for the popup to display), which means the points are not editable. It's really throwing a wrench into our field staff work tasks today!
They need to roll back the update immediately. There are so many issues.
